Thew a CEL after blowing off intercooler hose, 4 readings.
I blew off the hose connecting my UICP to my TB, and I threw a CEL, i got back
P0121 circuit range/performance problem P0102 Air flow circuit low input P0107 MAP circuit low input P0113 IAT sensor high input what happened??:confused: Im confused |
Thats going to happen if your ic pipe comes off. Fix the leak and reset the check engine light with a scanner( autozone or discount can do it for you)
Thats what I did, fixed the IC hose, and got it scanned. Thats what the readout came back as.
Does the CEL reset itself after a self diagnostic? |
No. You need to clear it.
alright. Auto Zone will do this?
yes
Auto Zone said they cant reset codes. After a few miles of driving, the CEL went away. That the lord! lmao
Originally Posted by SgtSeanzie
(Post 8421873)
yeah, next time all you need to do is remove the neg side of the batt and itll go away
you can also use evoscan.
Originally Posted by *constant_boost
(Post 8422025)
macbook ftl! |
