-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Car isn't firing. (https://www.evolutionm.net/forums/evo-general/501641-car-isnt-firing.html)
PurEvo Jul 4, 2010 01:09 PM
Car isn't firing.
I just had my motor built and running recently. I drove and put over 100 miles trying to break it in. While cruising on the interstate, my car suddenly started sounding weird. I put it in neutral to coast down but the car shut off. I've checked timing, which is good. Did a compression check, which is good and even across. Got fuel, got oil, got air. Checked all the couplers and vacuum lines, good. Everything seems good, except spark. Seems like 1 and 4 is sparking, but 2 and 3 isn't sparking. I've changed spark plugs, and coils, but same thing. 1 and 4 still spark, 2 and 3 still no spark. Anybody have any idea's??
jy951 Jul 4, 2010 05:04 PM
Is your check engine light on? Can you get a scan tool and read the engine codes?
PurEvo Jul 4, 2010 05:35 PM
There's no check engine light on. Oh, it's an Evo 9. I used a friends coils from his Evo 8 if that mattered.
PurEvo Sep 6, 2010 05:17 PM
Is there a way to check if the ecu it is going bad? People are thinking it's my ecu.
white_evo27 Sep 6, 2010 11:29 PM
try different coils? im no expert but if it were me i wouldnt be using evo Vlll coils in a IX
SpoolinUP has a good COP system to use! im about to order one this week!
OneEyedJack Sep 7, 2010 09:51 AM
Exhaust cam sensor. This just happened to me. I had fuel all over, spark on 2, it would not fire over. Most times it would start a bit, but die pretty much immediately.
Everyone thought it was my ECU as well. Turned out the immobilizer had tripped, and after I fixed that with ECUflash and got fuel/spark back, realized I only had spark on 2 cyl. I tried swapping coil packs, I had an evo 9 and put an evo 8 coil pack in that I bought used, made no difference, still only spark on 2. Swapped exh cam sensor, car fired right up.
I'm still driving around with 1 evo 9 pack and 1 evo 8 pack... :)
PurEvo Sep 7, 2010 04:21 PM
I sure hope your right. Now, i need to find my evo friends and see if they can swing by to let me test.
dmitirygolos Sep 9, 2010 11:58 AM
good luck on that
PurEvo Sep 10, 2010 04:19 PM
changed out the exhaust cam sensor. But it didn't fix the problem. The motor is running smoother though. But still not firing on 2 and 3. Any more ideas?
apexisilver8gsr Sep 10, 2010 09:55 PM
most likely its your ECU man
PurEvo Sep 13, 2010 06:18 PM
I'm not good with electrical stuff but this is what I did. I cranked the car and let it idle. I used a test light and touched the ecu pin for ign coil 1 and 4. The motor sounded like it wanted to shut off. I touched the ecu pin for ign coil 2 and 3. Nothing happen. Does this confirms that the ecu is bad?
PurEvo Sep 19, 2010 12:26 AM
problem solved. Had a short in the wire harness. The wire went to the coil for 2 and 3. It's all covered and motor is running good again.
Ecu wasn't the problem.
Drifting Away Sep 19, 2010 12:43 AM
I would upgrade to a spark tech system, havent driven on mine yet but my tuner tells my my car is doing much better with it on .
PurEvo Sep 19, 2010 05:01 PM
I want to. But i spent a good bit on an AEM EMS already. lol
