do the subaru 2.5's spool turbos faster then 2.0 evo's?
In general do the subaru 2.5's spool turbos faster then 2.0 evo's? If given the same size turbo for each car of course.
I would think the half liter extra would make noticably faster spool but not sure if the evo engine flows better thus making up for the smaller engine. any examples? |
Of course more displacement will spool a turbo faster. Search the site for examples of 2.3 strokers.
i had a 35r sti. hit 20 psi by 4,300 rpm in 3rd.
The Evo spools quicker. The Evo turbos are right on the outlet of the exhaust manifold. On the Wrx/Sti you have long unequal length headers and then an up-pipe to get to the turbo. Now one would argue that the intake track is shorter on the Wrx/Sti so the net-effect of boost getting into the engine is about the same. A lower mount intercooler on the Sti is FTL.
Originally Posted by TeStUdO
(Post 8676016)
Originally Posted by n2oiroc
(Post 8676167)
Originally Posted by njboy
(Post 8676252)
The EVO's turbo is also twin scroll so it may spool a little bit quicker if we were to be talking about a stock turbo here.
Originally Posted by Bobster22388
(Post 8676389)
yes
instead of arguing why doesnt someone post where a 2.0L evo spools a standard 35r evo at? im pretty sure its later than 4,300. especially with an open .82 t3 housing. btw, i also had a big front mount with a 2.75" charge pipe so a top mount would be quicker.
Originally Posted by casper3043
(Post 8676288)
i feel the evo's spool quicker also. although we have an 06 wrx in the family, the boost doesn't feel anywhere near the pull of the MR.
no were not talking about stock turbos here. were talking about a scenario with same turbo on each car. to get a good comparison, we'd have to do aftermarket turbos, both undivided housings like gt30r or gt35r comparisons or billet 6262's. same turbo on each car
someone with a lot of time on their hands do some searching on spool times on http://forums.nasioc.com/ and post back here. im curious on how much of a difference there is |
well they have a 2.5L with a smaller turbo........ ......
(Post 8676167)
{offtopic}**{offtopic} what kind of numbers did you make and what mods? ON TOPIC****** my 35r evo hits 25psi by 5400ish on 93 |
Originally Posted by italianevo88
(Post 8677308)
ON TOPIC****** my 35r evo hits 25psi by 5400ish on 93 ar fab built shortblock with 9.5:1 arias pistons, manley rods and blueprinted bottom end. stock heads and cams. modified u.r. gt3582r kit with .82 a/r v-band discharge turbine. tial 44 with 1.4 bar springs. maddad v2 header and whisper catback. perrin fmic. deatschwerks 1,150cc top feeds. boomba racing fuel rails, fuelab regulator and bosch 044. 4" filter on turbo inlet. hydra 2.6. tgv deletes. 93 octane pump tune is at 21 psi. 93 pump + 5 gallons Q16 race tune (roughly 40/60 mix) was at 28 psi. corrected it was 419 whp on pump and 540 whp on the mix. it had more but the bottom end was built for 550 whp so i stopped there. http://i153.photobucket.com/albums/s201/n2oiroc/003.jpg |
| All times are GMT -7. The time now is 06:01 AM. |
