-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Help light's (https://www.evolutionm.net/forums/evo-general/521545-help-lights.html)
dac001 Oct 25, 2010 04:56 PM
Help light's
didn't know were to post ithis.
it started to day at work went out for cig at 9am light were off. 11:30 lunch time lights were on... got home about 1hr later stepped out for a cig light were off.. went out side about 2 hrs later and my light were on. i have a turbo timer so i set my headlights off and my running lights on so my gauges say on when the turbo timer is counting down car shuts down then about 3/5 mins later the lights go off...like normal .... has anyone had this problem? or know what to look for... txs
evo milk Oct 25, 2010 05:22 PM
Wow my head hurt trying to dechipher that.
So you're saying your lights turn off and on randomly when you set your turbo timer? And you leave your light switch set on the parking lights?
dac001 Oct 25, 2010 05:30 PM
lol sorry for that....the T-timer is set to auto so when i get out of the car it stays running so does the lights. timer stops. car shutsoff light say on for 3/5 min then the lights go off like normal. then 1 or 2 hrs later light are back on.... hope this will help...\
Just on Randomly..
chaotichoax Oct 25, 2010 06:30 PM
first thing you need to do is check your driver's side kick panel and see if your wiring connections are corroded/water damaged
chaotichoax Oct 25, 2010 06:33 PM
https://www.evolutionm.net/forums/in...s-how-fix.html
dac001 Oct 25, 2010 07:19 PM
thxs. Will look into that.
dac001 Oct 25, 2010 07:57 PM
yep that's it .... thxs for the info/help...
Imports14life Oct 26, 2010 06:06 AM
Me too brother!
Problem #1: Its an Evo. Nothing is ever easy or goes right. Hope you get the problem fixed, sounds like a slew of dead batteries and push starts lie in your immediate future.
gsrboi80 Oct 26, 2010 07:56 AM
Originally Posted by Imports14life (Post 8783021)
Me too brother!
As Chaotic posted and linked to sticky. Common issue that lies in the drivers kick panel due to water getting into connectors and causing corrosion. Nothing a solder gun and a tube of RTV can't fix {thumbup}
