Can't Remove E-Brake Handle
I received the Rexpeed CF E-Brake Cover, but I can't seem to get the old one removed. I've twisted every which way, with all my might and it still won't budge.
What's the trick?:crap::confused: |
I've been wondering the same thing.. I've been meaning to get rid of this ricey MR one..
well idk if the MR handle and the GSR handle are the same but mine, a MR, has tiny screws on the sides...use an L key to remove them and the handle should come out effortlessly...but then again, i'm not sure if they're a difference in the handles....lol
I'm curious as well on how to remove it, as well as how the quality of the rexspeed e-brake is
Originally Posted by Hi Im Vinh
(Post 8938971)
Assuming you have the stock leather ebrake handle as opposed to the upgraded factory MR piece it can be kinda a pain to get off. My technique was that I grabbed a blowdryer and heated the handle up for a little bit and then just pulled it straight off.
Originally Posted by mx4life85
(Post 8938703)
Originally Posted by heel2toe
(Post 8939004)
no that'll work fine as well as long as you leave some distance to it so you dont burn the leather
i believe you just pull straight forward, no twisting.......heating it up will help it release.
It pulls off just dont let it go on accident and let it fly into the windshield.
i did mine i just use vice grip pliers to twist it off and avoid further accident lol...u just to have to be a little patient..
same, I used a yellow microfiber towel over it, and vice griped pliers. moved it sideways until it broke loose and it pulled right off.
Just intalled the same thing on my GSR, there were no holes on the stock one just twist them off no tricks at all, I think you just haven't twist it hard enough so it didnt came off(it was really hard to remove it tho), but for the rexpeed one it has 2 small holes at sides.
I cudnt twist mine off so this is wut i did... took my knife and cut down the center of the oem stitching and pulled off the wrap then took my knife and cut the rubber cylinder around the ebrake handle( u can take ur time i did to make sure i didnt scratch the ebrake handle )... time spent pulling on ebrake about 1 hr... time with knife 15 mins ;)
| All times are GMT -7. The time now is 12:43 PM. |
