Car cranks, but won't start, .... adivce?
Running on AEM Ems and weather is about -15c. I had a little trouble starting the car about a month ago so i took it to the tuner and got it touched up. Worked fine.
Wednesday i drove the car, and everything was fine. Yesturday morning i tried to start the car, and no go (won't start today either). It cranks, but doesn't start. I thought maybe something with spark plugs, pulled each out, and seem fine. I thought maybe its the Spoolin kit, and replaced it w/ stock coil, still nothing. Thought maybe its the fuel pump but i hear it prime when i turn the key in the on position... friend mentioned for me to check LICP, but everything looks good... Whats next? I made a log while startup and have aem tune on file if anyone can help. -dj |
Originally Posted by ezzey
(Post 8970463)
Wednesday i drove the car, and everything was fine. Yesturday morning i tried to start the car, and no go (won't start today either). It cranks, but doesn't start. I thought maybe something with spark plugs, pulled each out, and seem fine. I thought maybe its the Spoolin kit, and replaced it w/ stock coil, still nothing. Whats next? I made a log while startup and have aem tune on file if anyone can help. -dj |
Originally Posted by RoBear
(Post 8970503)
I had a similar problem that turned out to be a sensor used by the injectors. It burned out so the injectors weren't sending any fuel into the cylinders. My engine is completely stock, though, so your issuemay be related to your mods.
any info appreciated. |
i dont think you can hear the fuel pump prime just by turning the key.
check the obvious spark fuel compression pull out a sparkplug wire out and hold it next to the valve cover while cranking. if you see spark arching out to the valve cover, then you have spark. move on to fuel make sure you are getting fuel into the chamber. if you are, move to compression test |
It's the AEM Period.
Originally Posted by 05VIII
(Post 8970891)
check the obvious spark fuel compression pull out a sparkplug wire out and hold it next to the valve cover while cranking. if you see spark arching out to the valve cover, then you have spark. move on to fuel make sure you are getting fuel into the chamber. if you are, move to compression test I smell fuel, so i know im getting fuel, and compressoin SHOULD be good since cars been running fine, and only rebuilt about 5000miles ago. Ill check the spark plugs again, and gonna log crank and cam while cranking the engine and see if it picks up a signal. and yes, AEM seems to not like cold weather ;/ . Even thou it may be the AEM, there must be something i can do to get my car running. Just gotta figure out what, sigh. I may go back to stock ecu in the "near" future. |
E85??
crank sensor? it happened to me, i was just cruising and mine went out!!!! crazy for 38k miles i know but who knows.... machines aren't perfect my pulley backed out and i've never taken anything or loosened anything on that side of the motor
Originally Posted by evo9nuuub
(Post 8971271)
I just logged crank and cam sensor and they seem to both be working, aswell as "stat sync'd" goes on. I'll drop in new spark plugs, see if that does anything. Should my fuel pump prime everytime i turn the key on? sigh this blows |
(Post 8971387)
94 Octane
I just logged crank and cam sensor and they seem to both be working, aswell as "stat sync'd" goes on. I'll drop in new spark plugs, see if that does anything. Should my fuel pump prime everytime i turn the key on? sigh this blows check for spark first before you buy new plugs. you might not need them. if you can narrow it down to spark or fuel, you can go from there and figure out what is causing it to not function properly. |
Just my 2cents bro two days ago my car did the same cranked but didn't start I check everything no codes my fuel pump was not sending fuel. Check if you have fuel
Originally Posted by kakarot305
(Post 8971556)
(Post 8971659)
How you fix your issue? I gotfa check my fuse, not sure why i havent yet. Possibly fuse blown so fuel pumP isnt sending fuel afterm priming. Pretty sure i got spark but will swAp in my other new set of ngk's and gap them. Post results later
check your red 10A ignition coil fuse in the indoor fuse block. Mine keep blowing randomly and the car crank but just don't start.
Mine sort had the same problem a few weeks ago. If you have fuel (check by pulling the fuel line and crank the car it should start squirting fuel) and checked all your fuses (even the one under the steering wheel where your ignition coil fuse is located). If all that is good, then it could be your immobilizer.
| All times are GMT -7. The time now is 07:51 AM. |
