-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Newbie Question: Failed Smog inspection because my CEL light isn't working? (https://www.evolutionm.net/forums/evo-general/572324-newbie-question-failed-smog-inspection-because-my-cel-light-isnt-working.html)
CMoney Aug 30, 2011 06:33 PM
Hey EvolutionM,
Is the Service engine light and Check engine light the same>? I opened up the cluster and bulbs were all there. I checked the fuse and it wasn't missing anything. What can be this problem? Is the Engine service light suppose to come on with the other light when turning the ignition on 3? Any help would be appreciated.
4RETECH Aug 30, 2011 06:50 PM
Originally Posted by CMoney (Post 9571522)
Hey EvolutionM,
Yes, the light is to be on when the bulb check happens as you first turn on the key. see if the bulb is burnt out or if power is getting to it when you first turn on the key.
jaybird09 Aug 31, 2011 11:53 AM
clear the codes right before you go test next time!
Kracka Aug 31, 2011 11:55 AM
You can't just reset the codes and go in, the ECU needs to cycle a certain number of times before it'll pass OBDII inspection.
analogEvo Nov 17, 2011 01:44 PM
sorry to bump an old thread but did you ever figure out why it didnt come on?
i swapped the bulbs and it still didnt come on? is there a fuse dedicated to CEL?
SmurfZilla Nov 18, 2011 07:19 AM
Or you can flag OBDII readiness
CMoney Nov 18, 2011 10:56 AM
I swapped the bulbs in and it came on. So I assume check fuses. If not try another bulb.
