rjayjay |
Jun 10, 2012 12:07 AM |
03 Evo 8 Front Brake Problems
Hi guys, I just bought an 03 Evo 8 yesterday. I tried replacing the front brakes today since it made grinding noises and the pads looked really thin. I replaced the front brake pads with an autozone duralast gold brand and had the rotors cut. After installing the brakes, it still made that grinding noise that sends vibration to the brake pedal. Now what I'm wondering is that, should I have used a different set of brake pads? Should I buy a different brand since the duralast golds may not be compatible with the brembo brake system? or would it be the brake caliper? it makes a really loud grinding sound when brakes are put on at a low speed, then after driving the car for a bit, the noise disappears but the front brakes don't seem to be working very well. Please I need your help, it's a real safety issue and I'd like to fix it. I'm not very familiar with the brembo brake system. I'd appreciate it if any of you would share your knowledge. Please respond, thank you.
