-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Hot weather owners, how's the AC (https://www.evolutionm.net/forums/evo-general/620608-hot-weather-owners-hows-ac.html)
yenny Jul 17, 2012 09:12 AM
I've owned cars before that had trouble keeping me cool during the FL summers. How are the evo AC's. Temps here in the summer are around 98deg
Ramen_Noodle Jul 17, 2012 09:13 AM
Meh, definitely not the coldest blowing AC but it's not that bad either. It can be a pain on a stock motor/tune though, the motor can be boggy with the AC on.
gsrboi80 Jul 17, 2012 09:23 AM
Still cold after almost 10yrs/Never been as cold as other cars though
Never been recharged, I don't use it too often but it def still does it's job
yenny Jul 17, 2012 09:32 AM
As long as I'm not sweating in bumper to bumper traffic, then I'll be ok. It sounds like the air conditioning is up to the task
evodriver49 Jul 17, 2012 09:34 AM
ac on with my kelford cams getting off the line..the car would lose from a 5-40 roll to a prius ive floored it for funsies and because of the vacuum drop the lag is HORRIBLE/EMBARRASSING lolol! i was making a left turn from the street into my neighborhood this weekend and floored it with oncoming traffic and BARELY made it across. maybe hit 15 tops by the time i crossed the 2 lanes hahha
ToddRhodes Jul 17, 2012 10:04 AM
We are not normally a hot weather climate up here in northern IN but this summer has been brutal - mid to upper 90's/100's and high humidity so I have the AC on constantly. Car is mostly stock but is tuned at 24 psi and the AC is more than enough to keep me cool with the windows closed, not so much with the windows open but unless you smoke I don't know why you'd do that anyway. I've noticed it's a little "slow" just off idle in 1st gear but otherwise it's peppy as ever out of boost and in boost, well, forget about it :)
sloow hatch Jul 17, 2012 10:06 AM
i hate my car ill have cold ac one min n then itll go aWay the next, . . now sometimes it works n sometimes it dont!. . . i dont understand
Kracka Jul 17, 2012 10:09 AM
My IX's A/C was able to handle TX heat and so has my X's.
Kracka Jul 17, 2012 10:10 AM
You probably are low on refrigerant, recharge the system.
Black94TSi Jul 17, 2012 10:26 AM
My 03's ac works very well. It's just a pain in the butt to take off with it on (twin disc). Other than that it's just how I would expect it.
dab262 Jul 17, 2012 10:30 AM
My AC works just fine. With a stock motor/tune, having the AC on sucks and the car is very sluggish at low rpm.
meckert Jul 17, 2012 10:38 AM
VIII, No real issues, tuned for low rpm power--recharged a/c last year with a new comp and drier--working better then ever this yr. Not the coldest--but better then other cars I have owned.
Pssst Jul 17, 2012 10:40 AM
Before pulling my motor(ended up emptying my AC {thumbdwn} ) my AC blew FREEZING cold, that regardless of the temp outside I would get the frosties on the windshield O_O I was convinced I could freeze vodka with my AC....
I really hope once my motor goes back in and I recharge the AC its just as cold :cool:
sloow hatch Jul 17, 2012 11:30 AM
they already did that n itll work sometimes, . .n like right now its hot outside n it aint working!
Jschlo4 Jul 17, 2012 11:37 AM
AC???? windows down is my AC.
