Car won't crank at all.
Hey first I want to say that I did search and tried finding out as much as I could before posting this. My problem is my car does nothing when I turn the key to start. You can hear the fuel pump but the starter doesn't click at all. Everything else gets power all the accessories are fine. It has a new battery and terminals, I checked the fuses and tested the relay all are good. I checked the wires on the starter and they are all connected and seem fine. I would say its the starter but it was replaced less than three months ago when the clutch was installed. Any other ideas? Oh and I also checked the starter voltage at the power side and its getting 12v.
Pull the small wire off the starter and rig a jumper long enough to reach your meter with you in the front seat. Depress the clutch and turn the key to start and check if you get 12 volts. If the answer is yes, reinstall the wire. Try to start again and listen for starter solenoid click. If no sound, the starter is bad. Otherwise, something electrical inside is bad. It could be the ignition switch or maybe the clutch switch.
Originally Posted by barneyb
(Post 10616487)
Make sure your trans is grounded. Also pull it out and have it test to make sure its working it only two bolts just dont forget to unplug the battery when removing the starter.
Sounds like your starter went out. Try hammering on your starter with a hammer or ratchet or something. If it starts up then your starter is bad.
Even though you had it installed a short time ago it's always good to check the little things. A starter being over charged or faulty wiring can cause a starter to burn out early |
Originally Posted by raven1231
(Post 10616492)
Forgot to mention that I unplugged the clutch switch and tried starting it in neutral and had no luck.
Originally Posted by 3gturbo
(Post 10616715)
It wont start without the clutch switch.....
This happened to me as well, no sound at all when trying to start it. I first replaced the starter...no luck, then I replaced the clutch safety switch...nothing changed. I finally replaced the ignition switch, that was it all along. The easiest way to check the ignition switch is to try and crank with a really fast turn of the key. It sounds silly but when your ignition switch starts to go, that is the only way to start your car. Eventually though it will stop all together. The switch is 78 bucks tax included at Mitsubishi and is very easy to install. Any question let me know.
| All times are GMT -7. The time now is 07:31 AM. |
