Evo 8 rear wiper stopped working...
My rear wiper stopped working in the snow...it got stuck like it couldnt push enough snow from the rear windshield while it was halfway in the cycle. I parked and went inside. The next morning it was back in the normal position but never turned on again. It wouldnt move but the rear sprayer still works...i checked the wires and they all seemed to be plugged in..did the motor burn out? anyone else experience this?
Sounds like a burned out motor to me...
Originally Posted by Evobeatsvette5
(Post 10663844)
Originally Posted by AJCaron12
(Post 10664103)
Did you check your fuse? Why are you trying to run wipers with that much snow on the windows? That's what happens.
mine stopped working in the snow once, wouldnt go back on for a while and then magically.......started working again
i would cheak for power on both rear wires on motor if not bybass wires by putting on ground wire on battery and one wire to power on motor and see if you could get it to work if it works cheak power and ground
