I need to pass smog, please help.
Hello everybody, I own a 2006 evo and it has greddy ti-c comp turbo back exhaust. Unfortunately I do not have the stock parts to swap it out. I am trying to spend the least amount of money to try to fix this problem. If anybody is familiar with this exhaust system, is there a way that i could buy a down pipe and catalytic converter that can attach with the other half of the Greddy system and would allow me to pass?
If not any advice would be highly appreciate it. Thank you :) |
that greddy cat back should just bolt up to a stock cat
if the greddy downpipe doesnt bolt to the stock cat, then you can get a ebay knockoff for $80 and use that for smogging purposes. Good luck Fred |
Do you have the CEL on ? I just noticed youre on Cali, good luck!
They Visual inspect there still?
Originally Posted by blowngasket
(Post 10718228)
I passed with an oem cat. no problem. the cheapest route would be to rent/borrow a complete stock exhaust from a local or friend or just put the cat on if it is compatible with you aftermarket exhaust.
here all they do is OBD it and your done, the guy was looking at my HKS hi power exhaust and was prolly thinking How the F**K did this dude pass. but here no visual inspection due to time constrants.
Originally Posted by SilverShadow03
(Post 10718496)
Originally Posted by aamoedo
(Post 10718530)
Or buy the rally cat test pipe. Cars pass the sniffer with test pipes all the time.
(Post 10718530)
You must be mistaken or are not wording your statement correctly. |
thanks for al the replys. i appreciate it. it looks like i need to get my hands on a cat. how do you guys feel about high flow cats? are there any you recommend? i have been looking at "pace setter" and "berk technology". If not what is the best way to get my hands on a stock cat. thanks so much for the help, u guys have saved me.{thumbup}
Don't wast your time on a HFC for smog purposes. Go ahead and use a HFC once you pass smog. I would get a hold of an OEM CAT and use it for smog purposes only....then swap back to your original setup.
Like I previously said, I FAILED miserably with a HFC. Albeit NOT a new one but still failed miserably. I'm in the Bay Area too. I am about to remove my Evo 8 Cat and store it until I need to pass smog again. I had to smog it in August '12 and have been lazy in swapping back to my 3" tbe PLUS I've enjoyed the quieter exhaust note! LOL If you want to work something out, let me know I'll rent it to you for what I paid for it and I would refund you ALL your money once you return it. I'm assuming evo 8/9 cats are interchangeable? What is your time frame for getting it smogged again? |
(Post 10718770)
No worries...I'll be holding on to my OEM CAT for this very reason, LOL.
I'll keep an eye out for you in case I see any CATs for sale...I am on here daily. GL! |
(Post 10718504)
I pass cali smog with a helix cat-back and megan dp all the time |
