Help guy's
What would cause your engine load to be stuck at 21psi :helpme:
Where are u getting this number?
Originally Posted by cfdfireman1
(Post 10862836)
Checked the map wires with volt meter .... reads 4.9 damn thing is maxed out. with engine off
So chris you cant boost over 21 lbs?
No i cant give the damn thing no gas it stalls out.
Originally Posted by IEXCELR8
(Post 10863406)
Originally Posted by PHILLY EVO
(Post 10863498)
sounds like a bad sensor.
Originally Posted by BDecker9
(Post 10863572)
Soooo... what I got from this is, you HAVE to give it gas or it stalls out?
yes |
the map should not be reading 4.9 volts with engine off
| All times are GMT -7. The time now is 02:16 AM. |
