Ecu question???
When I bought the car, It had a aftermarket ecu. I bought an stock evo viii ecu. So my question is. Is it ok to just switch and plug in the stock ecu?
Any ideas help. Thanks. |
Need more info, what ecu was in it? What map sensor is on the car? A lot of times other ecu's have different sensors ie. air intake temp, wide bands, oil pressure and temp, among many other sensors that the stock ecu won't be able to recognize.
Originally Posted by gpfury86
(Post 10916230)
Originally Posted by OPENA(671)
(Post 10916871)
The current ecu is an apexi power fc. The only sensor on it is an apexi safc2. I'm planning on taking that out too. Besides that, everything is stock. Hope that's the info you needed.
Cool. I'll try it out. Thanks.
depends on your mods on the car. what if it is an ecu tuned specifically for the set up. be careful.
Originally Posted by misterevo8
(Post 10917383)
What's the worse thing that could happen? |
oh, you will be fine with basic bolt ons. i do suggest however, once you get the stocker ecu on it, get it tuned for optimal performance and reliability.
(Post 10917680)
I switched my ecu, now it won't start!!! What's could be wrong?
Did you load a tune into the stock ecu that's compatible with your car/setup, the injector scaling many things could be wrong to cause it not to run. BTW by my earlier statement I didn't mean to start the car and go floor it, i just meant to get the car started and idling, the ecu will need to be tuned for boost most likely unless it's a bone stock car, which with a stand alone I highly doubt it is.
