cold outside can't start my evo
Guys what the hell happened.tonight was -2* next morning I couldn't start my car.motor was cranking but didn't fire up.shall I spray a little starting fluid or try to pull it with rope and put it in second gear.I have that car for 6 years and never happed before.I'm on 93 octane,basic modifications.the strange thing is that I drove from work and parked on my drive way like always.it drove fine,nothing was wrong.any input appreciated.
how old is your fuel pump?
My car takes ~3 cranks in cold weather, but i have a mini battery and actual e85, not e70 crap
Originally Posted by Werdna06
(Post 11050095)
Originally Posted by shrtstuff89
(Post 11050101)
Place the car on ACC and see if you can hear the Wally working. Also, if your battery is old you may want to try testing it. It could also be a bad ignition switch. Keep us posted and good luck!
Originally Posted by Bhsj13
(Post 11050171)
Update.just got home and it's around 14* outside.after cranking like for 15 sec car fired up.all I can think off is fuel got so cold that it was unable to ignite.thanks guys....or fuel pump about to say good bye.
Oh, put that isoheet or whatever it is called in the tank. It will start up better. Thanks for reminding me, ill have to do the same also.
Cool thanks man.
(Post 11050171)
Originally Posted by egis
(Post 11050123)
You keep your car on the drive way as well?
What spark plugs are you running? Had that problem last winter when I was running BR8es plugs, went a step warmer to br7es for cold months, solved my cold starting issues. This was on E85 if that matters.
Originally Posted by LOLZFWD
(Post 11050797)
Your not going to hear the wally working until the car is cranking, being that the fuel pump relay is controlled by seeing a signal from both the crank and cam position sensor, as well as the ecu immobilizer. Unless of course the car was rewired for aftermarket pump applications.
Originally Posted by evowner17
(Post 11057883)
| All times are GMT -7. The time now is 04:26 PM. |
