Anyone else had issues it's their oil drains?
So for awhile there I had a mysterious oil leak that I could not find the source of. It was leaking on top of the starter and leaving oil on the bolts of the oil pan leading me to believe the oil pan was leaking.
After re sealing the pan and STILL having the leak I finally left the car running with the accelerator pedal down I discovered that the oil drain line was squirting oil. I finally took it off and discovered a series of small holes traveling down the tube that were on the ridges in the area of the piping that you can bend. I'm just wondering how many other people have had this issue?? Cheers Colton |
Are you talking about the oil return line from the turbo?
Yeah from the turbo to the oil pan I call it an oil drain
Havent had that problem myself. Easy enough fix though just replace the line. Make sure you get new gaskets for the line to turbo and line to oil pan. There is a correct way to install them too so do a quick search on the correct orientation.
No I know I already fixed it it was just an interesting problem and I was wondering if anyone else had had the issue. I'm not even sure how it is possible
was the tube actually leaking? Could it have been the Turbo to Tube gasket that was bad?
(Post 11095174)
Originally Posted by rjfg
(Post 11095181)
No there were literally small holes the size of a pen tip in the tube
mine has a small hole in it to i tlk to one of the guys at AWD they have a steel braided line they going to be puting in for me on friday if it helps any
| All times are GMT -7. The time now is 01:14 PM. |
