-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Don't know which is more common, 60mm or 52mm guages? (https://www.evolutionm.net/forums/evo-general/69872-dont-know-more-common-60mm-52mm-guages.html)
CJK Mar 12, 2004 08:43 AM
guys, just wanting you know your opinions on guages...if you have pics that would help. Just considering which route to go, thanks!
rocketscience Mar 12, 2004 08:59 AM
depends on electronic or mechanical. the mechanical i think the only difference is the size. If you put it on the steering column, get 52. otherwise you will block more of your cluster.
If electrical, then the 60mm ones usually give you more functions. peak hold, warning, etc.
I got 52 electronic. Has warning and I mounted it on the steering column. Search for 'Omori boost gauge installed' for pics.
Also, the standalone gauge cups seem to be mostly 52mm.
bluevilevo8 Mar 12, 2004 08:17 PM
I had a greddy 60mm peak hold on my column. I mounted it slightly off to the right, and it didn't block anything. Come to think of it I still have it. Anyone want to take it off my hands?
Corey Mar 13, 2004 03:23 AM
1 Attachment(s)
I have 52mm Defi that are not is the car yet.
vr430 Mar 15, 2004 08:28 AM
pm'd yea {blob}
ammitsuevo Mar 15, 2004 07:03 PM
I also have the greddy 60mm electronic warning meters( boost, egt) I have no complaints with them. I would agree with the other members thought, the 52mm will create less blind spot if mounted along the a pillar, and will also allow one to fit 3 in the stock din housing. Just my 2 cents
