Good clutch and website
I'm replacing the clutch on my evo 9. What's a good clutch and a good website to get one from?
Everything depends on your goals with the car, budget and what has been and what is going to be done with the car. So many options out there its ridicules.
subscribe on this.
I am interested for my 9 too. I am actually looking for a used one but if there's a website with a good deal I might get a new one. On my mods and goals on the car I think a single clutch kit should be fine.... Is your car more than 400tq? |
I went with a Competition Stage 2 (sprung) through MAP, it's served it's purpose well for daily driving and going to the drag strip once. I'm about 375/375 on VD, usually just putt around in the car, but will drive "aggressively" from time to time for fun. Can't complain, lots of others on here have had good luck as well.
I have heard good things about the Comp Clutch stage 2 and you can either order from www.englishracing.com or www.maperformance.com.
You can also look at the ACT HDSS clutch kit. I have it with their xtreme pressure plate and streetlite flywheel and its held up pretty good so far. its a noisy set and I had to adjust the pedal to alleviate the lockout issue but it has held everything I have thrown at it thus far. You can order it through maperformance as well. I have about 42K miles and about 30 launches since I have installed it and she is still holding strong. but I'm pretty sure I will need to replace sooner than later. My two choices are the ACT or Comp |
I will only ever use comp clutch again in any of my cars
Originally Posted by JorgeAvila
(Post 11374271)
What mods do you have? What do you use the car for? What are your future plans for the car, power-wise and usage-wise? How much wtq do you currently have/plan to have? |
+1 on we need to know your mods and plans. I have the HDSS from ACT but only pushing 326 to the wheels. I'm 100% happy with it.
