Evo 7 (Yet Another) Won't Start
My Evo have new battery everything is fine.
But sometimes when I arrive to a place an turn off my car when I try to start it after a few minutes it just wont start. Doesn't crank or anything but you can hear it is trying to I will check: -Starter Ground cable -Battery connectors I don't know, after waiting a couple minutes it starts normally PLZ HELP:mitsu: |
When it happens, try banging on the starter (with something heavy, rock , hammer, etc) if you can reach it. Sounds like the starter is getting stuck.
(Post 11385719)
I had this issue on my Old car, it was the Main Relay but I don't know with the Evo |
I checked everything but car if I turn it off won't start if I try within 5-10 minutes.
After that time it starts |
No one?
Originally Posted by danfalcas
(Post 11391545)
No one?
This might sound dumb, but check the wire on top of the starter with the black plug. And check the wiring for that as well. My wire was some how cut from the previous owner and I would have very similar symptoms.
Could be a loose connection on your negative or positive lead connection from your battery. I assume that when you turn the key to the secondary position that the radio and internal electronics light up? If so, it does not sound like a starter issue but a loose connections to the battery lead.
Originally Posted by dyang9000
(Post 11397876)
I need to replace this part but i cannot remember how its called but is at the back of the key module (In the figure i think it's #7) http://www.mitsubishiparts.net/media.../6/6265152.gif -------------------------------------------- To bring you up to date, we did a complete test of current and everything is well connected. It's not the turbo timer, the starter is fine al cables on the battery are tight and everything. The issue happens randomly. Thanks |
Originally Posted by flippymcbean
(Post 11397812)
Ignition switch. Exact same thing happened to my fiance's lancer.
Originally Posted by zebra4
(Post 11398111)
This is what I need to replace http://mlm-s1-p.mlstatic.com/pastill...7_092013-O.jpg |
So the result is that it was the negative from the starter loose.
| All times are GMT -7. The time now is 04:38 PM. |
