-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Should I get an ayc light on dash at start up? I don't... (https://www.evolutionm.net/forums/evo-general/712896-should-i-get-ayc-light-dash-start-up-i-dont.html)
poorevo4 May 11, 2015 09:08 AM
As above. Evo 4 Gsr. Has ayc but no light on dash.
Should there be one?
Car has questionable past and diff has been replaced previously.
DsmEvo87 May 11, 2015 07:22 PM
Check if bulb is still present people used to take out the bulbs behind cluster to "hide" this problem.. hope this isnt the case.
Does your abs light come on?
poorevo4 May 11, 2015 11:35 PM
Yes. I believe abs light does come on.
Not driving car atm due to so many faults so will check when I get home tonight but sure it does. I dash cluster hard to remove. I have half of it out anyway tbf.
Do you know much about the wiring on these cars as I have a bunch of earth's taped up under dash??!!!!
Cheers
poorevo4 May 11, 2015 11:36 PM
But should I see ayc at starts up just like battery and srs light for example? I assume so...
Cheers
DsmEvo87 May 12, 2015 04:38 AM
yes the lights should come on and after a few seconds go off and stay off.
good luck!
