COP with toyota coils, adding dynatek arc-2?
I have a spooling up diy cop setup using toyota coils, looking to upgrade to a cdi ignition as cheap as possible. Can I add a dynatek arc-2 to my setup? How would I wire it? Evo 9
1 Attachment(s)
It's been a long time since I did this but the extra wires are listed below and are not needed.
-purple/White Clutch Switch for Launch Limiter -Purple Retard Enable -Green Tach Signal I did use the harness that came with the cdi box. I made a diagram to illustrate how I wired mine up...im 99% sure this is how mine is wired but i don't have my car here with me so this is all off memory.. Attachment 271399 |
Exactly what I was looking for, thank you. Just to confirm you used Toyota coils and not montero coils?
Originally Posted by drinky84
(Post 11526218)
-purple/White Clutch Switch for Launch Limiter -Purple Retard Enable -Green Tach Signal I did use the harness that came with the cdi box. I made a diagram to illustrate how I wired mine up...im 99% sure this is how mine is wired but i don't have my car here with me so this is all off memory.. http://i12.photobucket.com/albums/a2...ad/dynatek.jpg |
Originally Posted by YFZracer32
(Post 11526637)
