Haven't driven my evo for couple years need tips
Due to some circumstances i haven't been able to drive ny evo 8 Besides putting in a new battery anything else i should check on before first start besides oil?
Drain and replace the fuel, check your oil and depending on how long it sat, check your hoses and all that good stuff
Where and how it was stored will have a lot to do with what you need to do. Stored in a climate controlled garage that was basically never opened... drain the gas, check fluid levels, check air pressure and go enjoy it.
Stored outside under a tarp will take much more to be sure no animals have chewed through wires/hoses or have made nests that could potentially catch fire and things of that nature |
Parked outside under a tarp. Should the oil be good in the engine and tranny?
Originally Posted by EvoooB
(Post 11525397)
Originally Posted by Mr J
(Post 11526325)
The main issue that I ran into were that my tires were completely shot because the air had gotten low over time and they developed flat spots. Also my brake rotors were in really bad shape from corrosion (don't know if you live in a dry area, might not be an issue). |
Definitely change oil and replace fuel.
For that amount if time it wouldn't surprise me if oil leaks may occur,or water leak from water pump. I would go to extreme and replace coolant and all fluids to be honest. just my 2cents. |
another proud evo owner who didn't have a chance in two years to fire up the car and let it idle for a few minutes lol
Makes u wonder about all those low mileage garage queens
Originally Posted by egis
(Post 11526606)
| All times are GMT -7. The time now is 01:29 AM. |
