Need help on my boost leak
I need help on my evo 8 i believe its a boost leak, i check my boost gauge its set at 15 psi but it goes all the way to 10 psi passed where it says (vac) on the gauge.
Errr, you mean when the car is running it's at -10psi?
in my experience boost gauges go bad pretty often. If you can, verify the gauge is accurate before taking too much apart. On that note though its never a bad idea to visually inspect all the hoses for anything super obvious.
Originally Posted by Epyon
(Post 11604879)
(Post 11604880)
Originally Posted by Evoguy!123
(Post 11604929)
Nope its 15. When im in a dead stop it goes to 10 and when i step on the gas boost collects and stops at 15.
(Post 11604932)
10psi of boost at a stop? Sounds like a bad gauge to me.
But you shouldn't even make boost at all during idle. It should be in heavy vacuum, My Evo X idles around -20 to -22 psi.
Are you going to listen to the people that are trying to help or just argue with them?
Originally Posted by razorlab
(Post 11604949)
[QUOTE=Epyon;11604944]But you shouldn't even make boost at all during idle. It should be in heavy vacuum, My Evo X idles around -20 to -22 psi.[/
Yeah i aint running my car its parked. |
Thank your guys for helping! This is why i love this form.
So borrow a compressor and do a boost leak test, should be done every year, when you get the pressure up you'll hear air escaping, I found a little broken vacuum pipe around the back on the injectors, never even knew it was there
check the EGR hoses under the intake I have had a few where one would pop off not a bad idea to zip tie all your vac hoses as well.
-20 to - 22 inches of vacuum not psi, you could divide it in half to get psi so -10 to -11 psi at idle
