-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   What's a good oil to run in a 2.3 (https://www.evolutionm.net/forums/evo-general/728493-whats-good-oil-run-2-3-a.html)
timmycat May 6, 2016 10:45 AM
What oils are everyone running? I've been using royal purple. I have a evo8 with a Built 2.3 and 272s. What would you guys recommend?
LetsGetThisDone May 6, 2016 10:47 AM
Water, no additives. And bypass the filter.
gsrboi80 May 6, 2016 11:03 AM
Consult your engine builder for proper oil weight, or you can do as stated above lol
Turndown May 6, 2016 11:13 AM
I run Brad Penn. Royal purple is way overpriced.
Biggiesacks May 6, 2016 01:33 PM
+1, it really depends on the tolerances your engine was built to, generally the looser things are spaced the higher weight oil you will run.
timmycat May 6, 2016 06:39 PM
How do I bypass the filter? I changed out my winter oil and put summer oil in.
gsrboi80 May 6, 2016 11:48 PM
Lol you don't bypass the filter...he was bustin your balls
desmvp May 7, 2016 04:13 AM
You should be running something with zddp and or with Molly in it for the turbo. If your not running zddp your slowly killing your turbo, I like running lucus race only in my evo 8 runs strong and I can tell when I have the crappy non-zddp stuff on it.�� Hope this helps.
Fast_Freddie May 7, 2016 11:57 AM
Either Brad Penn or Amsoil Z-rod for my cars... the weight is going to depend on what tolerances the engine was built at...
Teal2nnr May 7, 2016 05:12 PM
This. I'm partial to ZRod myself.
