Turn signals, Hazards don't work. Need help pleaseeeee
Hey guys,
So I been researching this issue that's been happening a few weeks ago and I hope someone can give some direction where to start digging. I replaced my steering column because the tilt function broke, that night everything worked fine till the morning. On my commute to work my wipers and turn signals don't work at all. On my old evo 8 MR I fixed it with the connectors by the left foot panel. This time on my evo 9 MR I did the same thing but the turn signals and hazards still don't work. I hard wired the wires and checked all fuses and I have both the 018 and 014 ETACS. I checked every fuse in the engine bay and foot panel with a voltmeter and still no luck. The only clue I have right now is that there's no power going to the 7.5 amp and the 20 amp next to it which is for the turn signals. I'm losing my brain trying to figure this out. I don't have a winter car until I get this fixed. Any help would be great and appreciated. Thanks! |
could the switch the hazards button thing be broken?
. ________________________________________________ 03 Evo 8, - Manley forged crank - Manley rods - Weipco pistons - ACT twin plate clutch - ACT flywheel - Millimeter oversized titanium exhaust valves - gates blue timing belt - AMS balance shaft delete - Garrett gt3076r turbo - Peak boost turbo manifold - AMS fuel rail - Larger intercooler - Large AMS oil cooler - Custom oil cooler high flow duct - 255lph walbro pump - 780cc precision injectors - Tial open dump wastegate - 3 inch turbo back exhaust - Sard r2d2 BOV... How it all makes me feel? ★★ Signature: ™007-License-Plate-Hide-Gadget by: www.TryDeal.com ™★★ |
After tearing the interior apart, checking every possible connection and relay and switch. The wire that powers the ETACS in the connectors in the kick panel that usually go bad from corrosion was the problem. We hard wired most of the wires that is visible with corrosion, and after testing the orange wire and pulling it apart, there was corrosion on the inside of the wire and not visible from the connection side. Ended up hardwiring the entire connector, which is probably what I should have done from the start.
Thank you every one for your input and help! |
Glad you fixed it
Flasher module.
Originally Posted by kaj
(Post 11731823)
Flasher module.
I've not heard of this happening. Why do the wires corrode? Does moisture get in there somehow?
Originally Posted by WW03VIII
(Post 11732157)
See gremlins sticky in the electrical sub forum
| All times are GMT -7. The time now is 12:39 PM. |
