-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Evo won't idle at all. (https://www.evolutionm.net/forums/evo-general/745382-evo-wont-idle-all.html)
The_Cleaner Dec 11, 2017 03:18 PM
Hello my 04 Evo won't idle at all. I replaced the iac and still nothing. I've seen that changing the egr solenoid valve would work. Any thoughts do have cams but car was fine couple days ago.
hutch959 Dec 11, 2017 04:21 PM
just to clarify...
car runs fine everywhere else... but just wont idle.
The_Cleaner Dec 11, 2017 08:30 PM
Yea just won't idle.
kaj Dec 11, 2017 08:56 PM
Mods? Tuned? Do you happen to have a wideband installed to know if it's stalling due to being lean or rich? Do you smell gas?
Have you checked all your vacuum lines?
Can you hear noise from the fuel pump?
What do the plugs look like?
Has the BISS been messed with?
There are soooooooooo many reasons this could be happening. Be patient.. it may take a while to guess the right one.
:D
The_Cleaner Dec 12, 2017 05:40 AM
Full bolt on's nothing to special. I'm gonna do a boost leak test to see if anything is leaking. I'm not patient just wanna drive her around. :yum:
Dakota Evo Dec 12, 2017 08:21 AM
ubiss screw
Tatmonster45 Dec 12, 2017 08:25 AM
Iac is probably done
The_Cleaner Dec 12, 2017 08:25 AM
I don't really know where to adjust it since I don't have evoscan.
The_Cleaner Dec 12, 2017 08:30 AM
I already replaced the iac thinking boost leak testing.?
Turndown Dec 12, 2017 10:28 AM
You're gonna have to get a computer with evoscan to park the IACV before you adjust the BISS. Then try starting it again.
The_Cleaner Dec 12, 2017 11:12 AM
Will do guess I need my tuner to come down here.
