-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   ID 1,700X or ID 2,000's (https://www.evolutionm.net/forums/evo-general/751225-id-1-700x-id-2-000s.html)
Manu PikaEvo Oct 8, 2018 08:54 AM
Hi guys, I'm Manu and I was looking for recomendations on injectors and whats the difference since I can run on both, I have an FP Red and want to make 500-650whp on pump 93 + Meth M5 and another map of E85. Im fully built, piston, rod, cams, etc. Fuel system upgraded, etc. Etc. Any help is welcome. Thanks.
LetsGetThisDone Oct 8, 2018 09:28 AM
1650's will be plenty for that.
Manu PikaEvo Oct 8, 2018 11:04 AM
Thanks for the suggestion. What if I decided to go 2000cc instead of., It'll be bad?
LetsGetThisDone Oct 8, 2018 12:23 PM
They're just not needed...
Manu PikaEvo Oct 8, 2018 06:12 PM
Thanks a lot!
Abacus Oct 9, 2018 10:32 AM
I would do the ID1700's over the ID2000's for what your doing. The ID1700's are a good match for what the max of the red will put out on Ethanol. I currently run the ID1700's and moved from the ID1300's. Great injectors that perform well under all conditions.
Ask your tuner what they prefer if you are on stock ecu. They may have base maps for xxx injectors and have hours into making them drive well.
