Stock Cluster & Boost gauge bulb sizes?
Some of the bulbs in my cluster as well as the boost gauge have blown out and I'm researching what sizes to get. I found a thread here https://www.evolutionm.net/forums/ev...lacemnmet.html that lists what each of the bulbs are in the cluster but doesn't quite tell me the part number/size of each bulb.
Does anyone know the correct bulb size/part number for all the bulbs in the cluster as well as the stock boost gauge? I attempted to take out the bulb from the boost gauge and all I see is something like "Stanley V-2" and "S.12V, 2W". In other threads I see size "74" but I'm not quite sure what this means. Still in other threads I see something like size "T5". Needless to say it's causing a bit of confusion for me. Hoping someone can shed some light. TIA EDIT: Found the bulbs on STM: https://stmtuned.com/products/gauge-...-oem-evo-7-8-9 Now just need to find out the right size/PN for the stock boost gauge bulbs. |
I think your answer lies within the part no.s noted on the bulb itself. Certainly the Stanley V2 2W (2 watt) will help get you started.
I currently have the same cluster & just recently lost the function of the oil temp gauge. I have ordered a set of STACK gauges (to replace the OEM cluster) & the Autometer gauge pod no. 20029 to house them |
Mitsubishi did not ever sell the bulbs separately so if you can't find whomever they bought the bulbs from you are SOL. Even if you make it pass the bulb issue eventually the oil temp sender will start to leak and since that was never sold separate from the gauge you'd have to keep hunting down used units since they stopped making those gauges about 9 years ago. Best bet is to ditch that setup and buy an aftermarket set from a company that is willing to support their gauges for sometime. I did that about 9 years ago and it was a good decision IMO.
These are all the bulbs for the instrument cluster:
(16) MR444536 / 14V-1.12W (1) MN134600 / 12V, 1.12W, T5 (3) 8180A001 / 1.4V, 1.8W |
Originally Posted by Doctor-EVO
(Post 11855025)
(16) MR444536 / 14V-1.12W (1) MN134600 / 12V, 1.12W, T5 (3) 8180A001 / 1.4V, 1.8W Now if someone can help me find bulbs for the stock boost gauge ;) |
