JDM Evo 8 doesn't have Map sensor
I recently just received all my bolt on parts and I just realized that my 03 Evo 8 doesn't have a map sensor... Ohoh
How's the tuner going to log boost without it? Or how is the car even running without a map sensor? Can I easily add/wire up a map sensor on? If so, what do I have to do? On the USDM evos, you can easily spot the map sensor right on top of the intake manifold but in my case, no bueno 🤦*♀️ HELP! https://cimg4.ibsrv.net/gimg/www.evo...922646ca9b.jpg https://cimg1.ibsrv.net/gimg/www.evo...8dbace01f0.jpg https://cimg9.ibsrv.net/gimg/www.evo...cfaaafa67d.jpg https://cimg7.ibsrv.net/gimg/www.evo...b78c93b5b2.jpg |
(Post 11855412)
Thanks, so pretty much i just have to run 3 wires from the map sensor to the ecu (pin 73, 81 and 92) and drill a hole on the that port where the map sensor is suppose to be? im a evo noob atm so, just to clarify, theres no way to log boost if i dont have a map sensor? also what about tuning wise, car cant be tune without it? thanks for your help 🙏 |
Originally Posted by palaBoost
(Post 11855418)
im a evo noob atm so, just to clarify, theres no way to log boost if i dont have a map sensor? also what about tuning wise, car cant be tune without it? thanks for your help |
Originally Posted by razorlab
(Post 11855419)
Can't log boost but you couldn't really with 03-05 USDM evos either because the MAP Sensor would max out. You can still tune the car no problem, just would need to use the normal factory load-target system.
and also like im still on the stock 8 turbo, not as much boost is present but when I get all the bolt on parts installed i want to be running around 23-25psi of boost and this is where i would need a map sensor, correct? Thanks! |
(Post 11855425)
Right cuz USDM evos come with 1bar MAP sensor but in my case, is it safe to say that theres no such thing as "maxing out" because there isn't a map sensor in play?
(Post 11855428)
No you don't need a MAP sensor to do any amount of boost. The tuner can still tune via load-target like it is from the factory. If you want a PSI-target tune then yes, you need a 3-bar MAP sensor
| All times are GMT -7. The time now is 04:00 PM. |
