| Caine Teki |
Aug 10, 2019 08:32 AM |
Would I make a safe 350kw+ with the set up I'm building????
I'm currently building a 89 vr4 short block with forged internals, 1mm oversized je forged pistons, eagle rods, standard crank, arp rod bolts, arp main bolts, acl race bearings (main and big ends) and balance shafts removed. I also have a evo 2 head with reground 272 cams aftermarket springs and retainers and aftermarket cam gears to bolt to the block with arp head studs once short block is built it will obviously have new cambelt water pump etc... bolt ons are 1000cc injectors, 500hp Walbro intank pump, ssq bov, frontmount intercooler, aftermarket oil cooler, ar70 turbo, steamtube manifold, 3 1/2 inch exhaust system and custom dump pipe off the turbo, 40mm tial wastegate, ngk 8mm ignition leads, ngk iridium spark plugs and a link g3 ecu... with what's been listed above could anyone tell me if I could get a safe 350kw+ with the set up I'm building I won't be running e85 it will be on pump gas 98 octane. Cheers
