What's causing this??
Does anyone know what's causing this and how to fix it?
https://cimg3.ibsrv.net/gimg/www.evo...a1e79ff2cf.jpg https://cimg5.ibsrv.net/gimg/www.evo...54b4adbd55.jpg https://cimg1.ibsrv.net/gimg/www.evo...cfc4004a15.jpg |
I am guessing a leak from the hose?
Otherwise do you notice you are pushing coolant into the overflow after boosting? To put your mind at ease, I would definitely burp the radiator and check if bubbles keep popping. So you can catch a problem early on if it's a blown head gasket. |
looks like its time to replace your hoses. Get new clamps while you are at it.
Originally Posted by Evo9_Dubai
(Post 11935100)
I'm still new to Evo world, but in my Honda days, this was indicative of excess pressure in the system due to a failing head gasket. The compression would push coolant out the reservoir or the weakest clamp/hose.
Originally Posted by RobbieOh
(Post 11935111)
Check if the metal neck has corrosion or deposits on its exterior. If it does then a new hose will also leak. Clean it up to a smooth metal surface.
I'm not sure what you mean by " There nothing in the overflow after boosting". If you mean the reservoir is empty, that's not right. |
Originally Posted by SUPER fly TSi
(Post 11935110)
I would, just for peace of mind, burp the radiator and make sure there is no head gasket problem. I had a similar issue and diagnosed a blown head gasket very early. Replaced it and all was good to go. |
| All times are GMT -7. The time now is 09:28 PM. |
