Coolant hose kit?
Are there any coolant hose kit available in silicone for upper and lower hoses along with all the rest of the coolant hoses?
Originally Posted by BrunoBoy650
(Post 11971541)
this one looks nice. no logos
https://www.ebay.com/itm/13395118508...Bk9SR9LXjq67Yg |
Thank you! I wish I could mix and match, I’m running a 6 radiator so the upper hose I have to buy separate lol.
This just made me think of 2010 when there were about a billion of everything for us to choose from...
(Post 11971558)
Originally Posted by osetsky
(Post 11971559)
I could use new P/S hoses but says no good for oil so idk
Originally Posted by Kevin.
(Post 11971566)
I messaged the seller from eBay, he swapped the upper radiator hose for a evo 6 to match my setup. $100 shipped via PayPal. Thanks again
now if you want it to look awesome put some wire loom sleeve around it :lol:
They came in today, looks good. Will update once I change them all.
I have one straight house and two longer hoses I have no idea where they go. The 6 upper hose is a bit long to use with a Mishimoto radiator. Otherwise it’s pretty good and I would recommend the kit if changing hoses. Stock spring clamps do not work on this application.
(Post 11971960)
got a pic of the ones you didnt use? you probably deleted some hoses already |
(Post 11971962)
you'd want shinny new spring clamps anyway. pretty sure I used the original clamps for rad hoses and heater core. I dont use worm clamps anywhere in this car
got a pic of the ones you didnt use? you probably deleted some hoses already I have one that’s straight that I didn’t use and I’m pretty sure two for power steering. I did have block offs to the throttle body but did use them this time. Unfortunately the spring clamps did not fit over the stock hoses. I’m unsure if they’ve made them thicker since you purchased. |
