timing belt failed prematurely
shifted at 5000rpm and it was done...belts only like 2 and a half years old with barely 49000km on it
shop suspects that the balance shaft seized aint gonna be cheap to fix i assume |
Nope, its going to be expensive. I had a similar failure where the tensioner failed. In my case it broke the valves off and wrecked the cylinder walls so I ended up pulling it and building the motor.
Good luck and enjoy the eventually stronger engine lol |
I confirm it will cost you a lot I had the same problem too.
when mine broke around 55k miles, replacing the belts and sensor is all i did
(Post 11973951)
Originally Posted by schuhie
(Post 11973973)
That's pretty lucky. I wish that would have been the case for me lol.
(Post 11973985)
yup super lucky. it broke coming out of a hairpin turn
