What's the best dual pumper setup?
I currently have the buschur dual pumper kit on my evo 9 and it has the notorious leak issue lol. I was wondering what are you guys using for your dual pump setups! Please no leaky ones lol
Originally Posted by chizwizzzzz_
(Post 11976817)
I would get a better idea of why/where yours is leaking and probably just fix it.
Bulletproof racing has the best one by far. Look at those your wont be disappointed.
Appreciate your guy's responses! Will definitely look into those setups! TY
Originally Posted by schuhie
(Post 11976823)
Radium/BPR/EvoSpec
(Post 11976817)
You may not need a double pumper setup in the first place, which would simplify your setup, make it cheaper, and make it more reliable. You'll be able to avoid additional leak issues as well as the risk of one pump failing during high boost. Walbro makes a 525lph and a 535lph pump (without the internal check valve) which are good to over 700+hp. A single 450lph pump is good to the upper 650hp range. |
Originally Posted by Pal215
(Post 11976960)
What are your current power goals?
| All times are GMT -7. The time now is 02:25 AM. |
