-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Can I change the factory guage's lights? (https://www.evolutionm.net/forums/evo-general/82413-can-i-change-factory-guages-lights.html)
Hong Kong Evo May 27, 2004 02:50 AM
I was just wondering if anyone has changed the lights in the factory guages ? or is it even possible to do so ? thanks.
Hong Kong Evo May 27, 2004 04:07 AM
Does nobody know ? please someone help ?
jerastan May 27, 2004 07:17 AM
sure it's possible. do you want to change the speedo/tach or the a/c? i've had my cluster out and it's just a matter of changing the bulb condoms. of course the face overlays are orange, so you'll have to deal w/ finding new faces or somthing. i just ordered the ralliart meter combo. it's still orange/red but w/ white faces, 180mph speedo and a 10k tach.
Hong Kong Evo May 27, 2004 03:31 PM
I wanna change the speedo/tach lights ... cause I can't afford to get new guages ... I dont know I was planning to change the lights from that yellowish to a intense red ... and I was trying to figure out how to take that thing apart...
MagicNinja May 27, 2004 03:45 PM
Here are a couple ideas for ya......
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2480358525 <--- I got this and it works great.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33678 <--- This one lets you pick whatever color you want.
{thumbup}
jerastan May 27, 2004 05:53 PM
it's soooo easy to take the gauges out. just remove the bezel around it (2 screwws) and then remove the few screws that hold the gauge pod in place. You'll have to turn it a bit funky to get it out and unplug the 2 harnesses from the back. Once it's out you can see the back of the lights. just twist them and change out the bulb condoms. you'll have to do a search on here for the right size, but there are lots of posts. good luck.. {thumbup}
jeremy
Zeus May 27, 2004 11:08 PM
Hell, this old man just wants brighter lights in there... They say your sight goes first...
zstryder May 31, 2004 03:25 AM
I'm fine with the color... can we just make it brighter somehow? Sometimes they seem dim at night... especially compared with my friend's Mazda6 gauges. Those red LED displays are so bright it makes me jealous. :(
Zeus May 31, 2004 07:56 AM
That's my point...
plokivos May 31, 2004 01:50 PM
You could change the LED on the Gauges. I've seen it done. it's fairely easy.
There are few forums on DIY at prelude forum and also SRT-4 forum. I think it started at Prelude Forum. I use to have a 5th gen lude...
Just got to take the gauges out and replace the LED with higher Wattage/intensity LED.
Some soldiering and welding/splicing, ect.
I'm thinking about getting a Delfi electronic headup display and taking the whole Tech out. Maybe replace it with 3 other functioning gauges...
I was thinking about that in the shower today.
Best thing to do is just replace the whole system with Electroluminescent system.
El lighting but not as cheesy as ebay stuff.
zstryder May 31, 2004 03:07 PM
Well, the Evo gauges use bulbs - people tried using LED's before but the spread is just not good enough (small angle LED vs. the bulb's wide angle), so only certain parts of the display are lit up.
paradoxic May 31, 2004 03:11 PM
pics?
Zeus May 31, 2004 03:31 PM
Any one know a part number for slightly higher wattage bulbs?
Hong Kong Evo Jun 4, 2004 01:35 PM
how bout the factory boost guages and volt guages .. can those lights be changed ?
vegasboy301 Jun 4, 2004 01:54 PM
i want to know this as well :confused:
