-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   What's Our evo's actual weight??? G-tech owners help! (https://www.evolutionm.net/forums/evo-general/82562-whats-our-evos-actual-weight-g-tech-owners-help.html)
fr34k May 28, 2004 01:37 AM
Just got the G-tech pro comp and wondering what's our evo's actual weight to be put in into the gtech..
and i have a problem with the rpms...
i have calibrated the rpms and when i go to the drag mode and the tachometer is wrong! it even jumped to 6k out of a sudden and stayed there...
have anyone experienced this?? what should I do??
please help.. thankss
o3evo8 May 28, 2004 02:15 AM
check the inside door jam on the drivers side for the weight of the car on the tag with the tire presures. as for the g-tech issues i couldn't help you
erioshi May 28, 2004 02:37 AM
The RPM callibration thing has been covered before. I usually turn on the headlights and then callibrate; if that doesn't work try adding the blower fan. I set the high RPMs to 6500 and the low RPMs to 1500. I also have a friend calibrate the G-Tech so I can focus on the road and tach. :)
For weight I have been using 3500 lbs. I have an Evo with a sunroof, generally 3/4 tank of gas and me.
Mike W May 29, 2004 12:34 AM
http://www.roadraceengineering.com/e...evoweights.htm
Mike W
erioshi May 30, 2004 11:53 PM
Thanks for the Link!
