How to instal UR HF Cat
Old Mar 31, 2005 | 12:52 PM
4-BNGR's Avatar
Can I just use ramps to do this (I'm lowered on springs)? Put a jack stand under the midpipe and downpipe, 4 bolts, and that's it, right?
I just want to know if ramps will do it?
Old Mar 31, 2005 | 12:54 PM
justchil's Avatar
Depends how far the ramps bring it off the ground.. and how skinny you are
I had no problems putting on a full exhaust with jack stands.
Old Mar 31, 2005 | 10:16 PM
PVD04's Avatar
You should be able to do that. One problem I had with mine was that the cat would touch the heat shield. It didn't touch it just sitting there, but with engine vibrations I would get an awful rattle. I would check clearances before you take the car off the ramps. I used a sheet metal screw to hold the heat shield to the bottom of the car. Hope this helps. Oh, and you shouldn't need a jack stand under the downpipe, just the midpipe.
-Paul
D1andonlyantman
Nov 1, 2015 05:32 AM
luvboost
Jun 15, 2011 11:39 AM
ggevoIX
Apr 24, 2008 08:24 AM
boostedwrx
Oct 15, 2006 06:55 PM
twan
Dec 6, 2004 05:31 PM
