official PLX R-500 install thread
Old May 11, 2005 | 08:27 PM
djmikeymike's Avatar
i going to order the PLX R-500 by the end of this week. i know their are some other people that are looking into this unit too. So anybody that is working on this install please put any info you have here .
PLX Forum
R-500 and ECU+ (the ECU+ can read Knock A/F and EGT with the R-500)
wideband O2 senser install with pics
ecu wire pin outs:
link one
link two
evomoto link
PLX Wire pin out
i just got it today
Old May 12, 2005 | 04:05 PM
justchil's Avatar
Bump.. I'll have mine tomorrow morning.. I was doing a little reading and it says you replace the front o2 sensor with the wideband?
Old May 12, 2005 | 04:08 PM
justchil's Avatar
I found one other thread with like 4 different people saying 4 different things. It also looks like you will have to use a resistor if you want to replace one of the OEM o2's. I'm thinking about just having a bung welded in now :\
Old May 12, 2005 | 04:10 PM
from what i have read you can but that is in the 02 Housing and i think that will shortn the life of the wideband. I'm going put mine before the HFC...... i just ordered it from Gruppe-S great pice with the EGT probe......i also hear that we will be able to log and display boost with an update coming very soon....i'm asking on the PLX forum i will let u know
Old May 12, 2005 | 04:14 PM
justchil's Avatar
That would be nice.. I just got the m500 unit and I'm already kicking myself in the *** for not getting the r500
I also don't know if I trust any local shops even to weld a bung on :\ I don't know if they think my car is rice and don't care about doing a good job.. or if they are stupid/not trained. It looks like there would be less wiring if you do have a bung put on.
Hopefully someone that has installed one of these will see this thread '
BTW: I just picked up a o2 sensor socket from Sears.. looks pretty sweet
Edit: Here is another pin-out diagram from plx
http://www.plxdevices.com/ECUDatabas...MIT_EVO_03.pdf
Old May 12, 2005 | 04:20 PM
i can't wait to get the r-500 i think i will be the first person to install it the EVO
Old May 12, 2005 | 04:25 PM
justchil's Avatar
I'm not looking forward to hooking it up :\ More wires to tap in on the harness.. You don't happen to have an safc do ya? Just curious if people are tapping into the same exact spot for both wideband/safc on the harness.
Old May 12, 2005 | 04:27 PM
yes i have the AFC and im getting a Blitz ebc.......i think im going to get the wire harness might make it easier......
Old May 12, 2005 | 04:28 PM
justchil's Avatar
Yeah I have a fields harness but still.. you're going to have wires that have 2 and 3 wires spliced into them.
Edit:
I'm also curious to see if people are wiring int he signal wires on the ecu.. this simluates the narrowband signal.. I'm assuming this will prevent a SES light. Although it does say "optional" in the forums.
Old May 12, 2005 | 04:34 PM
no problem i do Audio/Video and Networking installation.......i love wires....splicing is not a problem do it all day long........ just knowing what the wires im splicing into do...... that is the problem
Old May 12, 2005 | 04:36 PM
what do you plan on logging?
1:
2:
3:
4:
5:
6:
Old May 12, 2005 | 04:39 PM
justchil's Avatar
I've been there done that lol.. I drilled a hole in my brake booster while installing a hallman cockpit controller last week so after fixing that the last thing I want to do is get under the dash again
I think I'm going to change my order if it's not too late and get the R500. I just read this and now the R500 is looking even better.
The M-500 is not capable of measuring knock, but the R-500 implements a sofisticated knocking algorithm which normalizes your background engine knock noise to filter and detect knock.
Old May 12, 2005 | 04:40 PM
plus you don't need the laptop to datalog
Old May 12, 2005 | 04:43 PM
justchil's Avatar
I just wrote the guy to see if it's too late to change my order.. I was having it shipped same day so I don't think it's even left yet. I can't believe I overlooked these things when doing research
Hey you're going to update ur first post with all the good info right? This thread is already getting long with us chatting
I'm also looking into the ECU+ and selling the AFC.......check this out
