EVO 8 Rear Seat removal
Old Jan 10, 2009 | 05:59 PM
1hotrod's Avatar
I'm going tomorrow to pick up a set of rear seats from a 2003 Lancer Evolution. I've removed alot of rear seats from other cars but are there any special tips or tricks or tools needed to remove them?
Old Jan 10, 2009 | 06:01 PM
silver3g2000's Avatar
I believe there's a hex bolt you need to undo, don't quote me on that though. The front part of the seats have tabs you pull up but the rears are a little more difficult.
Old Jan 10, 2009 | 06:02 PM
I just looked and they're not hexed but I'm not sure of the size, I'll go look again and let you know what size the bolts are.
Old Jan 10, 2009 | 06:06 PM
hamx0r's Avatar
to remove the rear seats you have a tab to remove the bottom. that will then expose the three bolts you have to remove to take the back part of the seat off. After removing the three bolts lift the back part up and that will unhook them. Then wiggle them out past the seat belts.
Old Jan 10, 2009 | 06:10 PM
Let us know how it goes!
Old Jan 10, 2009 | 06:51 PM
1hotrod's Avatar
Thanks guys...I'll definately let you know how it goes.
Old Jan 11, 2009 | 05:51 PM
1hotrod's Avatar
Got em out in less than 5 mins..2 clips and 3 bolts with a 12mm socket...thanks..
Old Mar 19, 2009 | 02:44 PM
dp310's Avatar
What did you do with the seat belt ???
Old Aug 14, 2009 | 07:48 AM
Craig King's Avatar
Any ideas how much the stock back seat assembly weighs?
Old Aug 14, 2009 | 08:02 AM
GaBe511's Avatar
I was wondering this too. I might take mine out to get the tops of the rear seats restored because they are starting to fade. Damn you Sun!
Old Aug 14, 2009 | 10:03 AM
Craig King's Avatar
LOL - I was just going to take mine out to save weight at the Buschur Shootout on Sunday.
Old Aug 14, 2009 | 10:06 AM
YzBrad99's Avatar
Old Jan 3, 2010 | 04:31 PM
rayray7734's Avatar
do they lower so that the trunk is exposed from the inside? ive been looking for a tab or something but cant find one
Old Jan 3, 2010 | 05:55 PM
iloveboost's Avatar
the tabs are under the bottom seat cushion at the front
Old Jan 3, 2010 | 06:54 PM
rayray7734's Avatar
i thought those were to remove em
