How-To: EGR Removal VIII/IX (and charcoal/EVAP canister)
Old Oct 21, 2009, 04:24 PM
D-Mon3y69's Avatar
bumb for answer
D-Mon3y69 is offline
Old Oct 21, 2009, 04:44 PM
Evoryder's Avatar
^ For what answer?
Also, here's the part I got from JEGS, the plug in the head
Evoryder is offline
Old Oct 21, 2009, 06:37 PM
Redline06's Avatar
glad I came across this. Thxs
Redline06 is offline
Old Oct 21, 2009, 06:40 PM
EvoDan2004's Avatar
hum. that hole or port for the egr on the head. i never plugged that. crap i dident even know it was there. does it matter? i never had an issue but crap. i dident know it was there. haha
EvoDan2004 is offline
Old Oct 21, 2009, 08:02 PM
Evoryder's Avatar
It's best to plug it on the head keep the hot air away from the intake mani.
I also love JEGS, they ship stupid quick, always!
Evoryder is offline
Old Oct 21, 2009, 08:34 PM
D-Mon3y69's Avatar
Originally Posted by Evoryder View Post
^ For what answer?
what happens if the vent tube gets clogged?
Old Oct 22, 2009, 01:06 PM
kaj
kaj's Avatar
i have the EGR disabled in periphery (tephramod came that way). i still have all solenoids and lines attached. is this okay?
i will be removing the EGR valve and installing a block off plate. i like the idea of blocking the gasses coming from the head.. i'll have to pull the IM off and get to that.
kaj is offline
Old Oct 22, 2009, 02:08 PM
EvoM Super Moderator
fostytou's Avatar
FYI for tephra / EUDM guys. There is a different address for the 1d EGR turnoff table that MrFred Posted
Originally Posted by logic View Post
mrfred, are you sure about 1041 being correct for 96530006? It actually looks like 103d might be the right address for that ROM.
Originally Posted by mrfred View Post
You're right. I didn't actually check that one. I just assumed it would the same as all the later US variants. I'll fix up my original post in a few minutes.
Originally Posted by D-Mon3y69 View Post
but won't you pass a plug in if you go into the computer like u said? visual test no worried about. what happens if the vent tube gets clogged?
Yes you will pass a plug-in if you make the appropriate ECU mods. If the vent tube gets clogged there is a possibility of vapor build-up in the gas tank. It is unlikely that you will even notice it, but if there is a drastic temperature swing from when you fill up to when you next open your gas cap you will hear the air woosh in/out. Imagine sealing off a 14 gallon bottle and changing the outside pressure (though its not enough to do any damage). The worse problem would be if contaminants got into the fuel filler via that vent tube, but the risk is low considering the shape/position/valves on it/etc.
fostytou is offline
Old Oct 23, 2009, 07:56 PM
BluEVOIX's Avatar
Did any one notice a better MPG?
BluEVOIX is offline
Old Oct 25, 2009, 04:28 AM
Dragracer187's Avatar
isn't your fueltank vent also connected to the canister? if it is how will it vent? Won't there be pressure building up in the fueltank?
Dragracer187 is offline
Old Oct 25, 2009, 02:11 PM
kaj
kaj's Avatar
assuming it vents as my honda did, it will go to atmosphere and you may smell fuel from time to time. a bit annoying. not worth getting rid of the evap stuff, IMO.
kaj is offline
Old Oct 26, 2009, 08:44 AM
fostytou's Avatar
Ummmm
In general you should not smell any gas, if you did that would be a serious build up...probably enough to cause an explosion if parked in a garage. If there was that much bellowing going on the IM would be loaded with fuel vapors all the time.
fostytou is offline
Old Oct 26, 2009, 09:24 AM
awsome!!
kmcconn9 is offline
Old Oct 26, 2009, 09:26 AM
dmotors's Avatar
what happen if only install a block of plate on the manifold and block the hole on the head i lived all installed????
dmotors is offline
Old Oct 26, 2009, 09:59 AM
EVODreams's Avatar
This is easily the most informative evap/egr removal thread I have ever seen.
EVODreams is offline
Quick Reply: How-To: EGR Removal VIII/IX (and charcoal/EVAP canister)
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
