How-To: EGR Removal VIII/IX (and charcoal/EVAP canister)
Old May 13, 2015, 12:24 PM
  #286
JCevo805's Avatar
one of the most detailed write ups ive seen 😳👌
Old Jun 2, 2015, 02:57 PM
  #287
SWOLN's Avatar
If anyone has done this mod, make sure you get some type of filter/breather in place to keep moisture out. It seems one of our members has seen his fuel filter gel as a result of no filter and his FPR has some rust so it doesn't seat properly.
Old Jun 2, 2015, 05:25 PM
  #288
IzzyRS's Avatar
I just did this mod and need to get a filter on there. I guess I will check for universal ones at the auto parts store.
Old Jun 2, 2015, 07:59 PM
  #289
Fireescape's Avatar
I'm not sure if the 9 head is different but I used a 12mm NSS plug to block off the port. The hole is 10mm across, measured with a vernier, and 1/8 is 9.54mm or something. When I put the 1/8 Npt plug I had into the hole it just fell in, bit of a struggle to pull it back out. Tap a 12mm x 1.75 NSS tap about halfway in and screw in the 12mm plug. You might need to tap a bit deeper until you can screw in the plug flush. It's a very tight fit so no need for any thread locker, that sucker ain't going anywhere.
Old Jun 3, 2015, 07:03 AM
  #290
SWOLN's Avatar
It's for the gas tank not the head.
http://www.lubetechnologies.com/desi...breathers.html is the company he is going to try out for the check valved breather.
Old Dec 8, 2015, 05:56 PM
  #291
egis's Avatar
Old Dec 10, 2015, 09:07 AM
  #292
MrWolfe's Avatar
Just curious as to putting a filter on what part? I just finished the delete and have this..
Am I Missing anything? thanks in advance!
Old Dec 12, 2015, 08:41 AM
  #293
uneekvisions's Avatar
Originally Posted by wazzelby
I installed a Curt Brown extreme port IM and 70mm TB and removed the EGR as outlined here. Now I am getting a P0011 (Camshaft Position 'A' Timing Over-Advanced or System Performance Bank 1) code while cruising. According to my rom I have disabled the EGR system (it says to set it to 0 to disable). I'm running Tephramod 7 on my IX. I also have HKS 272 cams but never got this before making the swap and removing the EGR stuff.
I cannot find any information on how to log mivec in evoscan but I really need to figure out why this code popped up after doing the install and removing the EGR. If anyone has any info please reach out to me. PM is good as I don't get to check the forums as often as I like.
Here is how to log MIVEC, you only need to enable the Intake side for a IX since we don't have it on the Exhaust side. Good luck, I'm working on trouble shooting the P0011 code myself.
http://www.evoxforums.com/forums/showthread.php?t=26711
Old Mar 3, 2016, 04:55 PM
  #294
TougeGod7's Avatar
+1 where should the filter go?
Old Mar 3, 2016, 06:48 PM
  #295
SWOLN's Avatar
If I'm not mistaken it's where you have the cap ziptied in the first pic under in the rear of the car.
Old Mar 14, 2016, 07:50 PM
  #296
SW20Mike's Avatar
Just did my egr delete following this thread. Does anyone have a link to a check valve used in this step: Optional: Place the check valve with the side that was connected toward the intake manifold VTA and the other end on the EVAP purge line that comes into the engine bay (the fat one where it would connect to the bracket)
Old Mar 15, 2016, 10:43 AM
  #297
thepoint4life23's Avatar
I not 100% how the Evap delete work. So I need to black off the port in the head, and remove the box near the rear tire?
Old Mar 15, 2016, 07:27 PM
  #298
SW20Mike's Avatar
It's optional to remove the evap equipment in the rear of the car. What most do primarily is use a block off plate for the EGR valve, remove the vacuum lines, solenoids. Some go as far as to remove the intake manifold and plug the port in the cylinder head for the EGR. Everything is on page 1 step by step.
Old Oct 27, 2016, 05:11 PM
  #299
danfalcas's Avatar
where will the filter go?
Old Nov 3, 2016, 06:10 PM
  #300
wysiwyg's Avatar
Thanks for the awesome write-up. I don't plan on deleting my EGR, but this helped me find my way around the intake when replacing the valve.
Quick Reply: How-To: EGR Removal VIII/IX (and charcoal/EVAP canister)
