How-To: EGR Removal VIII/IX (and charcoal/EVAP canister)
#316
For those in the future that decide to plug the port in the head, I found the 1/8 plug to be small and goes in about an inch into the head and doesn't feel secure. After trying multiple size plugs, I used a 7/16 tap and screw, I would recommend using this size plug and not the 1/8th.
#317
Yeah it seems there may be variances in the size, on our 2nd 2006 MR the port was tapped for the 1/8" plug, and it was just fine. But I remember reading that someone else ended up using a 12mm plug because of the hole size.
#318
Help
Can I just go to step 6 and be done with it? And finish the rest in the ecu and be good? Just cap the two hoses on the throttle body, install the block off plate and leave everything else in place?
#320
The funny part about that port is that one side is actually a hole that leads to the #4 exhaust port IIRC. You don't need to remove the head, but just make sure you vacuum out the metal shavings from drilling and tapping for a plug very well. it will be very difficult to get a drill back there with the head on the car and you'll have to use a different style tapping handle so that it clears everything in the way. A good drill bit will pull material out of the cylinder head and keep it from entering the exhaust port, which could eventually hit the hot side of your turbo (assuming those parts are even installed). You may not even need to drill to be honest.
#321
#322
#323
How tight does the plug have to be into the head? I put mine in and fingered tight it with red loctite(not sure if the loctite will hold to how hot the egr gasses can get). I wasn't sure if you need to crank it super hard in the head, was scared to stripe or damage the thread tap I did.
#324
It has been a while but if I recall correctly the plug can't really go anywhere due to the intake manifold inlet size or bend radius. I'd compare the hole sizes and the radius and see if you think it could be a problem if it backs out.
That said I'd think firm is fine, but that is pretty open to interpretation.
fostytou (Sep 9, 2019)
#327
In my previous Evo 9 I did not use a check valve. I just tucked the hose away from direct path of debre/water splash . But since you asked, a check valve doesn’t sound like a bad idea. Something with a very light cracking pressure. But what happens if the check valve fails? I guess maybe the gas cap has its own relief valve for gasses to escape .
#328
thanks
yes these are the same questions I had
i am just worried about the possibility of excess moisture in the tank due to running e85
#329
I deleted the EGR and disabled in the ECU using the byte length value "EGR system Enable / Disable" set to 0 but I am still throwing a P0403 code. Should I also set FCA bit 9 to 0 as well to disable the EGR test. I thought this was unnecessary if the test was disabled using the byte length value? ECU is on 88590015 ROM. Any help appreciated. Thanks.
