How-To: EGR Removal VIII/IX (and charcoal/EVAP canister)
#78
High temp loctite (PST 592) is only rated to 400 degrees. I doubt it is doing much after the first hour of starting the car.
Even a high-temp RTV is only rated to 650 degrees, intermittent:
http://www.amazon.com/Permatex-81409.../dp/B000HBIB80
If you're really worried about it leaking:
http://www.deaconindustries.com/products.html
#80
#81
Would it be possible/worth the effort to just buy a block plate between the EGR valve and the intake? If so, do I need to get a tune or anything to not throw a CEL or risk any lean/rich spots?
I drive my Evo mostly on highways so I bet it throws some serious amount of exhaust gases into my intake
#83
BUT, you'll still be unnecessarily heating up the bottom of the IM (the port runs under the #4 runner), and as you can see from the picture of my DIY blockoff plate and OEM gasket, the hot gases actually corroded/ate away the edge of the OEM gasket on the "hot" side after only a few thousand miles, because of the heat of the EGR gases getting bottled up there. So it's not a good idea to just install the plate:
The right side of the gasket is the side of the EGR port the gases come to from the head; the left (undamaged) side is the outlet up the IM/throttle body area.
#84
Maybe you're right. But, you'll still be heating up the IM and defeating the real purpose. Plug and plate need to be done for proper egr disabling.
This isn't entirely true... with a plate where the EGR used to be, you can block off the gases from reaching IM plenum, because there's two sides of the port - one side where the gases come from the head, and another where those gases are routed to the plenum after the TB.
#85
Took me a while to find that hardware (all Home Depot had was a square-head 1/8" NPT plug, which I didn't see how to drive far enough into the EGR port)... eventually, I got a hold of them through a local Fastenal store (not the closest one to my house, but driving to a farther-away store was still way cheaper than ordering it through McMaster-Carr). They're only about 30 cents each at Fastenal, IIRC.
#88
Just finishing up w/the EGR delete mod...will it be OK for me to drive the car 140 miles to AWD motorsports for a new tune?
Or will the car run like **** and have issues before the ECU is modified?
I removed all EGR components, charcoal canister, FPR solenoid, plugged hole in head and installed EGR block-off plate, Magnus IM heat barrier gasket, and had IM & EM ported by Buschur.
Just wondering if anyone knows if I can drive the car to the tuner before the ECU codes are modified to disable the EGR & FPR, etc or must the car be towed?
Thanks
Thanks
#89
Thanks
Thanks
