fmic install, front bumper help
having trouble getting the front bumper off. Seems to be attatched behind the headlight. Do i need to remove the headlights to get the front bumper off? i got the screws in the fender well, the undertray and the part in the grill, any I'm missing?
no you dont!!!!!
10 mm scre in fenderwall
2 plastic clips in fenderwall
open hood.
by hood latch there are :
2 100 mm screws
2 clips(remove with flat head not phillips like type in fenderwall.
its still on after that, but just tug on it on each side and it will come off. dont be afradi to use some force
open hood.
2 100 mm screws
ok... I re-read your post. and I see u got everything off already. They have clips that u cant see that hold it on. similar to ones that hold interrior pieces together. you just have to pull hard on each side and it will snap out.
Did you get the screw plus the two plastic screws in each fenderwall?
