How to: Installing JDM Plate Bracket with JDM hardware
#46
I also bought all the brackets on russells page as he requested me to. Ended up using the original retainer which has the small arms for the usdm license plate and bolted the jdm license bracket to it. I did not know about the different lights with the jdm bracket so i ended up ordering new usdm lights which did not fit properly in the bracket but was able to bolt it only on one side, enough to hold it on.
#50
Alight guys. Got everything installed finally. After dicking with the exhaust for a day and a half it fits. Got the bumper installed with the light bracket and correct lights. They fit great as oem should. The plate bracket was another story. The crash beam sits closer to the bumper then the oem bracketing on the jdm cars do. The tabs sticking off the back have to be bent flat and then kinda rolled to bolt it up to the crash beam and have the plate sit correctly. I just eye balled it where I wanted the plate to sit. Then made all my measurement to center it. Drilled and tapped the holes in the crash beam and bolted it up. The usdm license plate holes don't line up with the mounts in the bracket as mentioned so I measured and drilled the plate.
Heliart
Jun 16, 2017 07:08 PM
RockmanX
34
May 12, 2017 05:10 PM
fast03evo
26
Mar 15, 2016 04:36 AM
