Greddy Profec B spec II settings
Old Jan 7, 2004 | 03:58 PM
HoustonEVO's Avatar
I just got a Greddy Profec B spec II. I am looking for settings that will let my high boost hit 19psi and hold to red line and lower setting for about 16psi that holds to red line. If anyone has these settings or close too it post here. Thanks in advance. (btw I am running a K&N intake the rest is stock untill my Buschur racing turboback comes.)
Thanks
Old Jan 7, 2004 | 04:15 PM
MrBonus's Avatar
I use 66% as my duty cycle (With Buschur catless turboback; without it, I'd assume it would be lower).
My gain is 0 and boost rise is at 17.
I set my warning to 22.5 PSI.
I see about 18.5-19 PSI with a slight taper to redline.
Edit: Changed my rise to 17 and have been seeing steadier boost levels.
Old Jan 12, 2004 | 03:58 PM
Wills1's Avatar
Hello
I to am wondering how to set up my profec b spec II,
I have a 1.8L GSR with a pod filter and 2/5 exhaust,
I would like to run it safe and run about 9psi in [Lo]
and 12psi in [Hi]
Any help would be great as I dont really understand the
set value, gain ect..
Thanks
Old Jan 14, 2004 | 06:45 AM
Evo11V's Avatar
Veteran: Army
I'm using 43% duty with 17 gain...
my gain set is 17.5
warning 21psi
I'm seeing peak boost of 20psi with average boost of 18.5-19.5 It falls after a certain RPM so it is hard to hold it steady. I dont know how Mr. Bonus is set at 66% duty I would be scared as hell i would see 25psi+
Old Jan 14, 2004 | 09:55 AM
MrBonus's Avatar
my gain set is 17.5
warning 21psi
It's probably because we have different exhausts and intakes.
I have the short ram AEM setup and a catless Buschur turboback.
Old Jan 14, 2004 | 12:11 PM
Evo11V's Avatar
Veteran: Army
oh... possiably. I have K&N pannel filter, RSR turbo back w/UR Hi-flow cat
Old Jan 14, 2004 | 12:17 PM
Quickshift's Avatar
I am running 62 duty cycle 17% gain 1.20 start boost 20% limiter 1.45 boost max before limiter run around 20 psi to 19.5 stay pretty smooth.
SiLLyEVO
Aug 19, 2010 09:36 AM
21Evo-lution
19
Feb 20, 2010 07:55 PM
blanknotice
Oct 9, 2009 11:47 AM
hamx0r
For Sale - Miscellaneous Automotive
Nov 7, 2006 06:52 PM
Makos1610
19
Apr 21, 2006 09:03 PM
