Major Problem! turbo timer + anti lock help plz.......
Old Feb 11, 2004 | 12:15 AM
edison's Avatar
alrite guys, took the car to the shop today and they installed the apexi safc 2, greedy profec b and the greddy tt. when i picked up the car, they said they cant install the turbo timer because of the aftermarket alarm i got(Clifford AvantGuard 5). i know it has a built in turbo timer, but still wanna get the gredddy anyway, then the anti lock came up. wat could be the problem? i searched already, exactly wat he said might be relays, sensor...etc. he told me to bring in the manuals and diagrams for the alarm so he can take a look at it and reset the car, is that gonna fix the problem? if you guys have any advice on installing the turbo timer on the AG5, with diagrams that'd be great
Old Feb 11, 2004 | 08:05 PM
edison's Avatar
alrite guys, they got the turbo timer working by using two relays, BUT they told me i cant arm the car during the count down!!! thats kinda stupid, stand there and wait for the car to shut off then arm it...wats the point of having the turbo timer then? i thought u can take out the keys, arm the car during the count down.
Old Feb 11, 2004 | 11:08 PM
inline4g63's Avatar
I got the same problem. CAnt arm wehn turbo is counting down. I can lock it, but just not arm it.
Old Feb 11, 2004 | 11:10 PM
nine4surfah's Avatar
Same delima here......while the timer is counting down i can lock the car but not arm it....
Old Feb 12, 2004 | 12:59 AM
edison's Avatar
i dont have the keyless entry, i have the alarm...wont even lock/arm....that kinda sux cause i have to stand there and wait
Old Feb 12, 2004 | 07:25 PM
edison's Avatar
dealership charged me 100 bux, still cant figure the problem they said they need another 1hr which is 100bux to see wats wrong...
Old Feb 12, 2004 | 07:33 PM
Quickshift's Avatar
They probably taped into a wrong line at the ecu with the s-afc or pulled a wire without noticing it.
Old Feb 12, 2004 | 07:49 PM
MYEVOVIII's Avatar
You dont have keyless entry I thought all Evo's came with that feature standard?
Old Feb 13, 2004 | 12:10 AM
edison's Avatar
yea i have an alarm, as of now im paying $200 for them to pull out the turbo timer and see if thats gonna fix the problem, HENCE the fact that 200bux wont get it fixed
Old Feb 13, 2004 | 12:24 AM
AWDTurbo4's Avatar
i have an hks type 1, a shop is going to intall it this saturday, also i dont have an aftermarket alarm what i have is the factory keyless entry. am i gonna have the same problem? with the car not arming after the count?
thanks
Old Feb 13, 2004 | 01:54 AM
edison's Avatar
well no, with the keyless entry all u have to do is provide the evo ecu wiring diagram for the shop and they can bypass it, in my case the avantguard 5 is a very very complicated alarm so i guess they didnt mess with it.
solution for my case, paid watever the cost for mitsubishi to pull out the turbo timer and fix the god dam problem, then have my audio guy that put in the alarm install the turbo timer....
Old Feb 13, 2004 | 07:27 AM
AWDTurbo4's Avatar
I see, where can i get the ecu wiring diagram?
good luck with that man!
Old Feb 13, 2004 | 11:29 AM
edison's Avatar
http://www.roadraceengineering.com/e...-ecuwiring.htm
Old Feb 13, 2004 | 03:00 PM
AWDTurbo4's Avatar
thanks man
Old Feb 17, 2004 | 10:03 AM
19.5PSI's Avatar
that's weird, my car arms when my TT is counting down. i had the dealer install the alarm for me. it uses the original keyless transmitter. i was shocked to find out that it will armed. MY WRX could never be armed while the TT was counting down.
