HKS EVC with pics
Old May 4, 2004 | 11:22 PM
bpclements's Avatar
Great write up man. I see that you have also been to Dairy Queen by that napkin in your glove box, LOL .
Barry
Old Dec 8, 2004 | 03:53 PM
scott88vr6's Avatar
How does this EBC set if you don't have the display. Is it as easy as turn knob A set, then turn knob B and set? I am interested in buying this EBC, but didn't really want to mess with a display.
Old Jun 5, 2005 | 08:49 PM
MI-4 EVO's Avatar
Has anyone got some better pictures on where to connect the hoses? Hard to tell exactly what sources are used with these pictures.
Old Jun 10, 2005 | 07:53 AM
mitsuorder's Avatar
Ok, I'm about to start an official thread/how to request on setting up the HKS EVC V. bishiboy or someone else with experience with this ebc could you do a write up?
Old Jun 10, 2005 | 02:12 PM
djmikeymike's Avatar
you should do one on the Blitz id-III also
Old May 29, 2006 | 08:04 PM
levo2nr's Avatar
Originally Posted by forum04pl
ok i checked and all of my lines are running to the correct places, however, if i am at a dead stop and go wot through 1st, 2nd, and 3rd, then it will hold where i want it to or a little bit less, but while i am driving around and i drop a gear it will boost much higher than i want so i must let off of the gas. also the knobs to set the % are backwards, the lower i put the % the higher the boost goes. what could be wrong because this is really pissing me off. thanks.
did u ever find out the problem with the % thing
i think i am having the same problem
Old Jul 25, 2007 | 07:11 PM
timmiii's Avatar
I have a slight problem, after I connected the 6mm hose from the wastegate and turbo outlet to the stepper motor and the 4mm from the vacum source, my BOV to the stepper motor. I don't seem to be getting any boost except what the preset boost level of the wastegate actuator.
I can't seem to figure out the problem, I made sure that there were no leaks in the system and all the vac lines are securely fastened on each end. I maed sure the waste gate was hooked up to the the "O" port and the turbo outlet was hooked up to the "I" port. No matter how high or low I turn the gain to it still won't go higher than 80 or lower than 75 kpa. around 11 to 12 psi. I have the HKS EVC V limted edition. A friend of mine told me to switch the vac lines around between the wastegate and turbo outlet. However, I'm hesitant because of what HKS stated. That this will cause overboost.
Any help is much appreciated!!!
Thanks
Tim
Old Aug 16, 2007 | 06:22 PM
timmiii's Avatar
Bump for some advise.
Old Mar 3, 2008 | 03:45 PM
0E3vobutt3r's Avatar
I understand that I need to cap off the stock bcs. but do you guys cap off the little bung on the intake pipe? I would also like to know a good place to tap in for my vac hose. (pics)
Im also reading the instructions for the greddy ebc and they hook it up to the fuels pressure regulator, and the hks instructions say not too. any and all help will be greatly appreciated.
Thanks guys
Buddy
Old Mar 3, 2008 | 10:00 PM
bump I know this thread is old. But some one has to know
thanks
Old Mar 26, 2008 | 09:51 PM
atomicapples's Avatar
what happened to all the pics?
Old Mar 27, 2008 | 03:10 PM
the pics are in the sticky if you search there are 2 of these. the sticky contains that pics and this is just to talk about it
Old Apr 7, 2008 | 05:43 PM
howmuch4onerib's Avatar
6. Run vacuum line from Intake Manifold pressure source to the "B" on the stepping motor.
What is this Manifold pressure source you speak of???
Can I just "T" into the vac line that I use for my BOV???
Or is this something totally different from that vac line?
Old Apr 8, 2008 | 04:38 AM
mitsuorder's Avatar
You could use that line as it is essentially the same but I would think that you would want the reference source as close to the originating source as possible. Then again running a longer line from the evc to the intake mani where that bov line starts might negate any of the benefits of that entirely
Old Apr 8, 2008 | 07:42 PM
I see what you mean. Maybe I'll try the line that I tapped my boost gauge into...Wait, will I still need a boost gauge after I install the EVC?
I used the line that is clapped to the valve cover for my gauge, does the line for the EVC replace the line for the boost gauge?
