How to make a Cool Air Scoop
I have read other threads of using a scoop to pick up extra air from the front end of the car. I t seems like a god idea to me but I didn't want to take the bumper off is I measured and measured and made a template the drops on WITHOUT removing the bumper. You cut out the attached scoop and the remove the 2 trim screws holding the snorkel on the air box, remove the 1 trim screw from the bumper and curl the scoop down behind the bumper. Works great!!!!
I used 26 gauge sheet metal from home depot. A unibit (cone shaped drill bit) for the holes. Tin snips for the edges and notch on the side. Then I sanded, primed and painted. $5.00 worth of materials.
Here is a thread discussing the scoop....
https://www.evolutionm.net/forums/sh...ght=cool+scoop
only took my front bumper off once, and that was just to insure a perfect fit to the bumper, installation process was the same as you described after that. nice template and a very good idea, aluminum is a little easier to work with.
here is a link to some pics of mine, should be very similar to Cajun Power's template, if not at least it will give you an idea of what to expect. And a
for Cajun's my family is from Breaux Bridge.
https://www.evolutionm.net/forums/sh...cool+air+guide
not trying to hijack, don't even really have enough time to make these any more, just wanting to show everyone what it might look like.
Here are some pics. I used sheet metal due to the fact that the aluminum seemed a little too soft. This will hold up under the 150+ BOH runs.
Yes, my car is dirty in the pics.... I was testing in the rain last night...
ok, so here's mine - the night i drove home from work with it on, i could swear the turbo pulled just a little harder when it kicked in. hp gain or not, i'm sure my car's happier getting cooler air.
i made mine a little longer/wider than the template said to. also, i had to make 2 scoops - the first one's holes were off by a bit.(due only to my printer's quality i'm sure) so if you use this template, just know you may have some trial and error.
CF Air Scoop
First a thankZ to Cajun Power for providing the measurements to the air scoop. Had some left over Carbon Fiber so decided to just make the scoop out of it.
Quite a rush job thus the poor quality. But hey it's a great idea and I love it under the bonnet.
ya, my cut-out ended up higher (all the way at the top, actually) - as you can see in my pics.
all around great little mod!
how well does the carbon fiber hold up against high speeds? i've never really worked with the stuff, so i don't know how strong it is when used in an aplication like this.
I guess the CF holds pretty well at high speeds... after all a lot of spoilers are made of CF too... ^^ I prefered the look of it over metal so its a treat to have.
Now considering making a front lip out of it...
the only reason i asked, knowing that wings are made of it, is that with wings air passes around them and with this scoop air is more directly impacting the material.
but a friend told me that CF is damn strong, i guess. good to know.
