C-clip and Anti seez, Where can I get this?
I'm looking for the c-clip for the 10.5. I never got it with my 10.5. Does anyone know where I can get this. And also where can I get the Nickel Anti Seize? I'm having a hard time finding these parts. If you guys can help me out that would be great.
Thanks |
Try Napa.
any local stores? not online.
you should be able to get them both at the hardware store
You should be able to find Anti seize at just about any auto store.
The C-clip will probably be harder to find. Since you have a part that is not stock for your car most of the "What year is your car, What make, what model? Hold on I'll look it up" auto part stores probably will not be able to find the right size clip. Napa or Carquest are usually better for things like that. I guess you could also call your local Mitsu dealer since the 05's had that hotside on them. |
mines an 03 evo8
Dont bother buying any anti seize...if you do the install this weekend and drop me a line I have some I bought for when I did my install
Originally Posted by dp2580
mines an 03 evo8
I was stating that most places like Autozone and Advance auto are only able to find parts based on make, model and, year. I was pretty sure you were driving either an 03 or 04 Evo already. |
Both can be found at a local parts store. Most have bins of bolts/clamps etc.. that u can sort through.
I've seen c-clamps at either lowes or home depot. |
does anyone have the part # for this c clip? is this part necessary for this install?
1 Attachment(s)
The clip holds the wastegate arm on the flapper
It is this https://www.evolutionm.net/forums/at...id=93741&stc=1 Any hardware store should have one. |
I've never heard that called a c-clip.. but you can get them at any hobby store too.. remote control cars use these to hold the body on :)
cotter pin (aka pivot pin)
http://www.pivotpins.com/img/catimgs/hrsprcttr2.jpg c-clips look like an O with a section missing - C ;) |
do you guys know what size it is?
Won't you be able to reuse the stock one?
